KB-32128: Unformatted SetPoint.
Question:
If I click on a data-type SetPoint, its formatting is lost, and random numbers are displayed (3564.5784888852, for example) instead. How can I fix this?
Solution:
In this case, the SetPoint may have been unformatted.To keep the formatting, you must change the SetPoint’s KeepFormatWhenEditing property to 1 – kfAutomatic.
Leave a Reply
