Using Libraries in Elipse E3: Introduction.
Several projects that take longer to be configured, due to their complexity and range, can be developed faster with object oriented resources and the Libraries available in E3, creating simple, objective projects, drastically reducing maintenance time.
Some of the advantages of ElipseX (E3 User Libraries) are:
  • Reusing code
  • Minimizing tests during development
  • Creating a default interface for the objects developed
  • Shortening development time of new projects
  • Protecting project content
When you acquire more experience in using E3 Libraries, development time becmoes much more focused on improving objects and not the application itself, because when modifying a Library, the application is automatically updated.
Este artigo foi útil? Was this post helpful?
Yes0
No0
Leave a Reply
