Script fired when user logs in/out.
Question:
Is there any event that is fired whenever the user logs in or out the system?
Solution:
Whenever a valid user logs in the system, Elipse SCADA will automatically call the application’s OnUserLogin script. Likewise, whenever a user logs out the system, Elipse SCADA automatically calls OnUserLogout script.
Print Friendly, PDF & Email
Leave a Reply
