Returning items sorted alphabetically.
Question:
At an application, a script is used to return all objects that are in a data folder. For example:
 For each obj in Application.GetObject(“Data”)
  MsgBox obj.name
 Next
Why are the items not returned in alphabetical order when executing this script?
Question:
This happens because when you use a for each loop, the system does not return data sorted alphabetically, but in the order that the objects were created.
To fix this problem, you must use the following script:
 Set data = Application.GetObject(“Data”)
 Set DataList = CreateObject(“System.Collections.ArrayList”)
 For each obj in data
  DataList.Add obj.name
 Next
 DataList.Sort()
 For Each obj1 in DataList
     MsgBox obj1
 Next
IMPORTANT: In order to execute this script, you must install Microsoft .NET Framework 3.5
SortedApp.zip
Leave a Reply
