Recording alarms in different databases and tables.
Question:
Can I create multiple alarm servers in an E3 application? If not possible, can two alarms be saved in two databases at the same time via Alarm Server?
Solution:
No, an E3 domain can’t have more than one alarm server simultaneously: there can be only one such object per domain, and it will be the responsible for acknowledging alarms. Currently, you can only save alarms in a single database and in a single table, which are set up at the Alarm Server, and no other database or table is enabled to do so.
Leave a Reply
