KB-36412: Editing the VerticalPercentFill property’s limits at run time.
Question:
How can I edit the values of a rectangle’s VerticalPercentFill property’s maximum and minimum limits at run time?
Solution:
To do so, you can create a Library and use an analog link to set up the values of the property’s minimum and maximum limits.
So, you must create an XControl with two properties linked to the VerticalPercentFill property’s minimum and maximum limits. Then, you must set these values to be passed to the analog link whenever the values of XControl’s properties are changed, which will change the limits’ values.
Attached to this page is an application that illustrates the point of this article.
Bar.zip
Print Friendly, PDF & Email
Leave a Reply
