KB-36113: Using the same driver with Elipse SCADA and E3.
Question:
Can I use a driver from Elipse SCADA with E3, and vice-versa?
Solution:
Yes, you can, because the supervisory being used does not interfere with driver’s usage.
Leave a Reply
