KB-34187: Driver for barcode reader.
Question:
Which driver is used for communication between E3 and a barcode reader?
Solution:
To identify the appropriate I/O driver for a certain application, you must first check the communication protocol supported by the device to be accessed by E3. So, you must identify which communication protocol is used by the barcode reader.
For this kind of device, the most common kind of protocol is ASCII, and in this case therefore you must use ASCII driver.
You can download all drivers by Elipse for free on our website.
Leave a Reply
