Question:
What must be changed in an application developed with the Elipse SCADA 16 bits when updating it to the 32-bit version?
Solution:
Pay extra attention to the following points when updating Elipse SCADA:
1. Communication
You have to set up communication again.
2. Historic and reports
The Historic saves information regardless of their format, so you must only change this object if you want to change how data is being saved. Reports only access this data, no matter how they are saved.
3. Recipes
There is no need to change recipes, because they are in Elipse SCADA’s proprietary format and do not depend on the computer’s bus.
4. Scripts
Unless that the tags used in scripts are renamed, the scripts will not need to be done again, because they do not depend on the computer’s bus too.
5. Graphic Screens and animations
Screens and animation do not have to be set up again, because they are in Elipse SCADA’s proprietary format and do not depend on the computer’s bus too.
