KB-33304: Disabling Blink property in a table link’s row at run time.
Question:
How can I disable a table link row’s Blink property via scripts?
Solution:
To do so, just access the object’s links collection, select the property containing the table link, and then disable the row’s Blink property.
Example:
Sub Button1_Click()
     Screen.Item(“Rectangle1”).Links.Item(“ForegroundColor”).Item(1).Blink = false
     Screen.Item(“Rectangle 1”).Links.Item(“ForegroundColor”).Item(2).Blink = false
Leave a Reply
