KB-31353: Query1′ is not valid. :16 Error Message.
Question:
Why is the message  Query: ‘Query1’ is not valid. :16 being displayed on an E3Chart’s legend Status column?
Solution:
This can happen when the pen requires a Query (that is, it is either a historic or mixed pen), and the informed query cannot be used.
Two of the most common reasons for this error are: a) the Query’s name was not set properly, or b) the Query was removed.
To fix this, we suggest checking E3Chart‘s settings for the Query’s name or actual existence.
Print Friendly, PDF & Email
Leave a Reply
