KB-31345: Parallel hardkey (Hasp-4 model) with E3 versions higher than 3.0.
Question:
Can I use a parallel hardkey (Hasp-4 model) with E3 versions higher than 3.0?
Solution:
No, you can’t. With versions higher than 3.0, you must use the HL model USB hardkey.
Print Friendly, PDF & Email
Leave a Reply
