KB-30793: Duplicated registers in the Database’s alarms table.
Question:
Why are some alarms registers duplicated when recorded?
Solution:
This happens when the main and the Standby application are recording in the same database, and the EnableSynchronization property is enabled (TRUE).
Leave a Reply
