KB-30670: Printing a report via application.
Question:
Can I print a report via Elipse SCADA?
Solution:
Yes. To do so, access the Organizer, and set up the printer in the Reports–Printers folder. Then, just write a script using the report’s Print() function.
Print Friendly, PDF & Email
Leave a Reply
