KB-29393: Folder to generate logs in Elipse SCADA.
Question:
What is the name of the folder that must be created for logs generated in Elipse SCADA?
Solution:
The name of the folder to be created in the hard disk root (such as C:, for example) is ScadaLogs.
Print Friendly, PDF & Email
Leave a Reply
