Question:
How can I resize E3Chart’s legend in the report via scripts?
Solution:
To do so, copy the following script to the report’s OnBeforePrint event. The lines in bold are responsible for resizing both the legend and E3Chart:
Sub OnBeforePrint
Set Chart = Report.Sections("PageHeader").Controls("E3Chart1")
set charttela = Application.GetFrame().Screen.Item("E3Chart1")
Chart.CopyConfig(charttela)
Chart.LoadData()
NPens = Chart.Pens.Count
Chart.Legend.Size = NPens*17
Chart.Height = charttela.Height + NPens*17
With these lines, you can: check the number of pens in the E3Chart, resize the legend, and resize the E3Chart, respectively.
