KB-28512: Setting up an alarm and displaying it on screen.
Question:
How can I set an alarm and display the active ones on screen?
Solution:
To do so, open the Organizer, select the tag to be supervised, and configure the limits on Alarms tab. For example:
  • Low; Value 10; Pri 1; Comment “Low Limit”
  • High; Value 90; Pri 1; Comment “High Limit”
Then, insert an Alarms object onto screen (bell symbol on the toolbar), and set it up:
  • Double-click the object to access its properties.
  • Set up the Alarm Type option as Summary on General tab.
  • Select the columns to be displayed on Message Format tab.
Print Friendly, PDF & Email
Classificação média - Average rating 4 / 5. Count: 1
Leave a Reply
