Question:
How can I set up a remote application in Elipse SCADA ?
Solution:
First,
make sure there is a PRO license in the client computer, and another license of any type (MMI, PRO, View) in the server computer.
The settings procedure is twofold:
- Setting up the Server application: add the Elipse TCP/IP driver, press Set up button, and choose a port (1 to 1024) and a maximum number of connections.
- Setting up the Client application: add the same Elipse TCP/IP driver (it doesn’t need to be set up).
Then, add a remote application and select the inserted Elipse
TCP/IP driver. When pressing Set up button, add the same port chosen in the server and a maximum number of connections.
NOTES:
- If the operating system is WindowsXP, port 80 may not work properly.
- Attached to this article is a demo application developed with Elipse SCADA version 2.29 build 092.
