KB-27979: Copying fields from a Historic in E3Studio.
Question:
How can I copy fields from a Historic to another in E3Studio?
Solution:
You can’t copy only the fields, you will have to copy the whole Historic. To do so, in the Organizer’s Explorer mode, you must select it and drag it to the Parent item (project’s name displayed right below Explorer) while holding the CTRL key.
From version 5.0 of Elipse E3, the E3 Studio import and export tool allows you to export a file of the type. CSV, to import the fields from a history.
Print Friendly, PDF & Email
Leave a Reply
