KB-25374: Changing the active alarms’ text color at Alarms screen object.
Question:
How can I change the color of the active alarms’ text on the Alarms screen object?
Solution:
To do so, set a priority for the alarm and double-click the Alarms screen object. On Colors tab, enable a zone of unacknowledged alarms, set a priority range and select a color. Thus, the alarms with priority in the configured range will be displayed in the selected color.
Print Friendly, PDF & Email
Leave a Reply
