KB-14481: Storing alarms continuously, but displaying only the last ones.
Question:
How can I set up the SCADA application to store alarms continuously, but display only the ones from the last 24 hours?
Solution:
To do so, first you must set up the Alarms object to record a large number of registers, which enables continuous storage. Then, you must insert a Browser to display the alarms, and configure a Query to display only the ones from the last day.
Leave a Reply
