INFO-0002722: E3 Server hangs when OPC driver initializes.
OVERVIEW
When executing a domain as a service connecting to an OPC server that runs on the same machine (also as a service), E3 Server hangs on initialization.
WORKAROUND
To avoid this kind of behavior, you must configure the OPC client to access the local OPC Server as a remote computer, placing the address of the local machine in OPCDriver’s ServerMachine property as \\machinename (example: \\server1).
THIS ARTICLE APPLIES TO THESE PRODUCTS
  • Elipse E3 version 2.0
  • Elipse E3 version 2.5
  • Elipse E3 version 3.0
  • Elipse E3 version 3.1
Print Friendly, PDF & Email
Leave a Reply
