Question:
Is there any Elipse I/O driver that can communicate with Siemens’ LOGO PLC?
Solution:
No; Siemens’ LOGO PLCs use a proprietary (closed/restricted) protocol, of which Elipse has no implemented driver. However, LOGO!8 has a native Ethernet interface, which enables communication with M-Prot driver.
Depending on the PLC’s version, you can use OPC communication. We suggest you get in touch directly with the device’s technical support to check whether the model being used is compatible with OPC protocol.
