BUG-0010196: Alarm messages are removed from E3Alarm when Domain stops
OVERVIEW
E3Alarm‘s alarms summary should keep all messages when Domain stops, but not when it closes.
HOW CAN I REPRODUCE THIS PROBLEM?
  • Run the Domain;
  • Activate a certain amount of alarms;
  • Stop the Domain;
  • In Studio, erase some of the AlarmSource objects whose alarms were activated;
  • Run the Domain again;
  • Stop the Domain again (the alarms from objects that have been erased are removed, and no longer appear in the summary).
SITUATION
Elipse Software has confirmed that this is in fact a bug from the products listed by the end of this article. The correction download can be found here.
THIS ARTICLE APPLIES TO THESE PRODUCTS
Elipse E3 version 3.1 or lower
Print Friendly, PDF & Email
Leave a Reply
