Question:
Can I add a watermark to a report?
Solution:
Yes, you can. Watermarks are texts of figures displayed under the document’s main text; these watermarks are added to the report via Watermark property.
To edit this property, select the ActiveReport object. To do so, click the rectangle on the report’s upper left side, as seen below.
