KB-28512: Setting up an alarm and displaying it on screen.
How can I set an alarm and display the active ones on screen?
To do so, open the Organizer, select the tag to be supervised, and configure the limits on Alarms tab. For example:
  • Low; Value 10; Pri 1; Comment “Low Limit”
  • High; Value 90; Pri 1; Comment “High Limit”
Then, insert an Alarms object onto screen (bell symbol on the toolbar), and set it up:
  • Double-click the object to access its properties.
  • Set up the Alarm Type option as Summary on General tab.
  • Select the columns to be displayed on Message Format tab.
Classificação média - Average rating 4 / 5. Count: 1
