KB-14481: Storing alarms continuously, but displaying only the last ones.
How can I set up the SCADA application to store alarms continuously, but display only the ones from the last 24 hours?
To do so, first you must set up the Alarms object to record a large number of registers, which enables continuous storage. Then, you must insert a Browser to display the alarms, and configure a Query to display only the ones from the last day.
