KB-33304: Disabling Blink property in a table link’s row at run time.
How can I disable a table link row’s Blink property via scripts?
To do so, just access the object’s links collection, select the property containing the table link, and then disable the row’s Blink property.
Example:
Sub Button1_Click()
     Screen.Item(“Rectangle1”).Links.Item(“ForegroundColor”).Item(1).Blink = false
     Screen.Item(“Rectangle 1”).Links.Item(“ForegroundColor”).Item(2).Blink = false
