KB-32988: Network settings for proper Viewer/WebViewer operation.
What are the basic network requirements for a good performance from the Viewer/WebViewer when connecting to E3Server?
The network settings’ minimum requirements for proper Elipse E3 supervisory’s operation are:
  • 128 kb of bandwidth dedicated exclusively to the supervisory.
  • Ping between Viewer/WebViewer and E3 Server of no more than 20 milliseconds.
NOTE: It is possible for the Viewer/WebViewer to work properly with less bandwidth or longer ping; however, it is very difficult to establish them precisely due to each application’s specificities.
