KB-41077: Prodave driver returns error when inserted into the application.
Question:
When Prodave driver is inserted into the application, an error message is returned.
  • In Elipse SCADA, the following message appears on screen: “Failed to load driver DLL ‘c:\temp\prodave.dll'”.
  • In Elipse E3, the following message appears on log: “Failed to load driver ‘C:\ProdaveDll.dll’ (LoadLibrary returned error 800700B6)”.
Why does it happen?
Solution:
This error message is displayed whenever the version of Siemens’s Prodave software is not compatible with the version of Windows installed in the computer.
Below is a compatibility table between Prodave’s and Windows’s versions.
NOTE: The complete, updated table can be checked directly at Siemens’s support website.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
