KB-35631: E3 versions and builds when using Remote Domains.
Question:
Why does the client Domain often disconnect from the server Domains?
Solution:
Probably, this happens because the client Domain’s version and build are different from the server Domains’ versions and builds. We recommend that you use the same version of E3 in all Domains.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
