Question:
How can I set up a Report’s Data Field to display the sum of the column’s values of a Database’s table?
Solution:
To do so, follow these procedures:
- Insert a GroupFooter in the Report.
- Copy the Data Field corresponding to the column with the values to be summed.
- Paste the Data Field into the GroupFooter, and set up the following properties:
- SummaryFunc – 0 ddSFSum
- SummaryGroup – GroupHeader1
- SummaryRunning – 1ddSRGroup
- SummaryType – 3-ddSMSubTotal
