KB-27806: LIB file not in the Domain folder.
Question:
When I execute the application, it displays a message informing that the Library’s files are not in the same Domain’s folder. Why is this message displayed and how can I deactivate it?
Solution:
This message is displayed to remind you that when loading the application into another machine, you must copy the LIB file to this new machine, because it is not in the same Domain file’s folder. It can’t be deactivated.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
