Question:
Using Studio x64, when I try to visualize a screen containing na MSForms ActiveX, the following error is displayed:
How can I fix it?
Solution:
To fix this error, you will need to install Office x64, which contains FM20.dll file. This component is necessary for MSForms to work properly at Studio x64. When using Studio x86 (32 bits), the library is already available, and you won’t need to install Office x64.
