Many times, you will need to sort out search results to display them in alphabetic order. To do so, you will need a script. This will sort the results out alphabetically via VBScript.
VBScript (Visual Basic Script) is an Active Scripting language developed by Microsoft that is modeled on Visual Basic. It allows Microsoft Windows system administrators to generate powerful tools for managing computers with error handling, subroutines, and other advanced programming constructs. It can give the user complete control over many aspects of their computing environment. One of its features are Dictionaries.
You will frequently use a dictionary when you need to store items and recover them by name. For example, a dictionary can hold all the environment variables defined by the system or all the values associated with a registry key. However, a dictionary can only store one item for each key value. That is, dictionary keys must all be unique. You should keep this in mind when creating a new one.
To use a Dictionary that returns search results alphabetically, that is, in ABCDE format, you will need to create a function called SortDictionary.
This article contains a demo application that illustrates how to sort out items alphabetically via VBScript with the ‘dictionary‘ object and the SortDictionary function. You will find the demo application for download at the end of this article; we also illustrate this article with an example of script that can be used for its execution.
Below is the code for the demo application at the end of the article:
'######################### Order Dictionary ########################## Function SortDictionary(objDict,intSort) Dim strDict() Dim objKey Dim strKey,strItem Dim X,Y,Z Z = objDict.Count Const dictKey = 1 Const dictItem = 2 If Z > 1 Then ReDim strDict(Z,2) X = 0 For Each objKey In objDict strDict(X,dictKey) = CStr(objKey) strDict(X,dictItem) = CStr(objDict(objKey)) X = X + 1 Next For X = 0 to (Z - 2) For Y = X to (Z - 1) If StrComp(strDict(X,intSort),strDict(Y,intSort),vbTextCompare) > 0 Then strKey = strDict(X,dictKey) strItem = strDict(X,dictItem) strDict(X,dictKey) = strDict(Y,dictKey) strDict(X,dictItem) = strDict(Y,dictItem) strDict(Y,dictKey) = strKey strDict(Y,dictItem) = strItem End If Next Next objDict.RemoveAll For X = 0 to (Z - 1) objDict.Add strDict(X,dictKey), strDict(X,dictItem) Next Set SortDictionary = objDict End If End Function
Related articles
