Question:
How large is an Elipse SCADA’s historic file (*.dat)?
Solution:
Elipse SCADA’s historic files are no larger than 2GB. Their records’ limit, even when the configured value is high, is 2147483647. When this limit is reached, the historic overwrites older records. Therefore, it’s important that your historic is set up properly, or to create a backup file for it.
