– Averages per minute: to obtain the averages per minute, you must retrieve E3TimeStamp’s seconds and milliseconds. To do so, multiply this field by 24 (to convert the time base into hours), and then by 60 (to convert it into minutes). The result must then be handled to isolate the integer, which corresponds to the minutes. Finally, divide everything by the same vale (1440 = 24 x 60) so that the data is converted again to date format. The result of these calculations will be used to group the data.
SELECT CAST(CAST(CAST(CAST(E3TimeStamp as float)*1440 as bigint) as float)/1440 as datetime) as Minute, AVG(Field) as Average
FROM Table
GROUP BY CAST(CAST(CAST(CAST(E3TimeStamp as float)*1440 as bigint) as float)/1440 as datetime)
– Averages per hour:
SELECT CAST(CAST(CAST(CAST(E3TimeStamp as float)*24 as bigint) as float)/24 as datetime) as Hour, AVG(Field) as Average
FROM Table
GROUP BY CAST(CAST(CAST(CAST(E3TimeStamp as float)*24 as bigint) as float)/24 as datetime)
– Averages per day:
SELECT CAST(FLOOR(CAST(E3TimeStamp as float)) as datetime) as Dia, AVG(Field) as Average
FROM Tabela
GROUP BY CAST(FLOOR(CAST(E3TimeStamp as float)) as datetime)
