Question:
I want to connect Elipse E3 to Excel 2013 via ADO, as in the script below:
However, when I try to connect it this way, the following warning message returns: “Provider not found. It may not have been properly installed.” How can I fix this?
Solution:
To connect with Excel 2013 via ADO, you will need to install version x86 (32 bits) of Microsoft Access Database Engine 2010 Redistributable, available for download in this link.
