Question:
How can I set up the NetWork number and PC number parameters in Mitsubishi’s Melsec-Q driver?
Solution:
The NetWork number (remote device’s network number) and PC number (remote device’s PC number) parameters are directly linked to the device being used. This information can be retrieved in the device’s software.
NOTES:
- NetWork number values can vary between 0 and 255. If the connection is local, the value is zero (default).
- PC number values can vary between 0 and 64. If the PC is local, the value is 255 (default).
