KB-60787: Querying raw data in an E3Storage.
Question:
Can I query the raw data recorded via E3Storage? I just want to visualize the actual data, with no interpolation function estimating values.
Solution:
Currently, E3Storage’s query has no function to return raw data. Therefore, you will have to create your own query and manipulate its SQL code directly.
An example of query would be:
      SELECT l1.E3TimeStamp, l1.FieldValue
      FROM TabelaStorage1 l1, (
         SELECT FieldID
FROM TabelaStorage1_Fields
  WHERE FieldName =
'<%varFieldName%>'
   ) l2
      WHERE l1.FieldID =
l2.FieldID
This sample query has a variable called varFieldName, which must be filled with the name of the desired field.
Print Friendly, PDF & Email
Leave a Reply
