Question:
Does Elipse SCADA have any function similar to VBScript’s InStr command (used in E3), which returns an integer specifying the occurrence’s start position of a string inside another one?
Solution:
No, Elipse SCADA has no similar methods; you will need to create a script to perform this function by using Len, Left, and Right commands. Len function will return the number of characters, and Left/Right will be used to check the desired string.
The sample application attached to this article was developed with Elipse SCADA version 2.29 Build 137.
