Question:
How can I run an Elipse SCADA application automatically as soon as Windows initializes?
Solution:
To run the application automatically from Windows initialization, just create a shortcut for the .APP file in Windows’ Startup folder. This folder is usually located at C:\Documents and Settings\UserName\Start Menu\Programs\Startup (Windows XP’s default).
