KB-55774: Exporting I/O tags from Elipse SCADA to E3.
Question:
Can I export a list of I/O tags from Elipse SCADA to E3?
Solution:
Yes, you can. To do so, you must access the driver in Elipse SCADA via Organizer, select Export button, and then create a file with .E2F extension to be imported in E3. By doing this, all tags bound to the driver will be passed to the file, as well as all their settings too.
Then in E3, you must: create a Driver object, right-click it, select Import option, and find the .E2F file; this will cause the tags to be imported from Elipse SCADA.
Print Friendly, PDF & Email
Leave a Reply
