Question:
Can I plot variable charts with different limits in E3Chart within a single 0 to 100% scale?
Solution:
Yes. To do so, there are two possibilities:
- On E3Chart’s properties window, Pens tab, Vertical Axis Link column, convert the engineering value into percentage using the variable’s minimum and maximum values (valid for real-time pens); or
- Create an axis for each pen, whose scale goes from the minimum to the maximum value reached by the variable. Leave these axes hidden, and display only a common axis whose scale goes from 0 to 100%.
Obs.: Method 1’s legend will display percentages, unlike method 2’s, which will display engineering values.
