KB-51223: Developing E3 applications with Power Studio.
Question:
Can I develop and edit E3 applications via Power Studio? What must not be done in order to avoid problems in E3’s projects and libraries?
Solution:
Yes, you can use the Power Studio to develop and/or edit E3 applications, because both programs share the same framework.
When using this software with E3, take the following precautions:
  • When creating a new application, delete PowerConfiguration object.
  • Don’t use Power-related objects (substations, feeds, measurements, commands, etc.).
  • Don’t use Power-related properties and methods, such as Viewer’s GetPowerExplorer() and ShowPowerExplorer() methods.
Print Friendly, PDF & Email
Leave a Reply
