Question:
How can I set up the blink for a link that changes the color of an object?
Solution:
To do so, you must edit the Viewer’s BlinkTime property. This properties establishes the time, in milliseconds, between each status change whenever an object is supposed to blink (that is, every time a screen object has a link, and Blink option is enabled). This property’s default value is 200 ms.
