Question:
How can I disable a button only for certain groups of users (for example, to keep users not belonging to Administrators group from accessing it when they are logged in the application)?
Solution:
To do so, you must first make sure all users and groups are properly registered in the application. After that, follow these procedures:
1 – Create an Internal Tag (Boolean) in the Viewer called Enable_User.
2 – Create a script in Viewer’s OnLogin event with the following code:
Item("Enable_User").Value = IsUserMemberOfGroup("Administrators")
3 – Create a simple link in the Enabled property of the button you wish to hide in the application with the value of Enable_User‘s tag.
