KB-45960: Animating JPG and BMP files with rotation.
Question:
Can I animate *.JPG and *.BMP files with the rotation effect?
Solution:
No, you cannot. You can only successfully animate vector figure files with the rotation effect, such as Windows Metafile (WMF).
Before you insert the animation, follow these procedures:
  1. Right-click on the figur.
  2. Select the option Convert into Symbol.
If our file was originally a *.JPG or *.BMP that was further converted .WMF, you still will not be able to animate it with the rotation effect. To do so, you must create a new figure and save it in .WMF format.
Print Friendly, PDF & Email
Leave a Reply
