Question:
Is Elipse SCADA CE compatible with Windows Embedded CE 6.0?
Solution:
Yes, Elipse SCADA CE is compatible with Windows CE 6.0.
However, we can’t guarantee it will work properly with the devices being used. Unlike PC hardware, which is standardized, hardware with Embedded-type platform, which run SCADA CE, is not standardized, which requires manufacturers’ customization.
NOTE: This test was developed by emulating a Smart Device via Visual Studio 2005 with Windows Mobile 6 professional, ARM920T Device Emulator processor, and Elipse SCADA CE HPC2000 Pocket ARM.
