Question
I want to use the FindFirstFile function to search for a file, passing as a parameter only a part of the filename. Is it possible?
Solution
Yes, it is. To do so, just use an asterisk (*).
Example of script:
tag001 = FindFirstFile("C:/Name_of_file*")
In this example, it could retrieve results such as Name_of_File1.txt, Name_of_File222.bmp, etc., regardless of its extension.
